AV Connections - Help needed
Discussion in 'Blu-ray & DVD Players & Recorders' started by Albo1960, Apr 18, 2005.
  1. Albo1960
    Albo1960
    Mar 4, 2005
    33
    I'm sure that (a) this has been asked many times before and (b) what I need is out there somewhere - it's just you can probably help me find it a lot quicker than I can do it.
    Is there an idiot's guide to linking up all of our AV equipment?
    My kit is
    Old Panasonic TV (two scarts)
    Panasonic Video (two scarts)
    Hauppage Freeview box (one mini scart)
    Cheapo DVD player
    I'm about to buy a Tosh RDXS34 and will then buy a better TV
    My main aim is to DVD record lots of my old videos
    Can you show me the right direction to go?
    thanks
    Albo1960
  2. bonzobanana
    bonzobanana
    Aug 21, 2001
    3,446
    Yeovil
    +219
    Assuming the Toshiba will replace the cheapo dvd player too so you can use that elsewhere in the house. Connect the Freeview box into the Toshiba scart input. Connect the Toshiba scart output to the Panasonic's main (RGB) scart socket. Connect the video to the Toshiba's phono composite/ audio inputs at the back (if it has one). If its a svhs video connect it via s-video at the back instead on the Toshiba. With regard the RF/Aerial connection put either the Toshiba or video first depending on which has the best aerial signal boosting ability. No point putting the Toshiba first if it slightly attenuates the signal or vice versa. You can if you want also connect the video to the tv via the second scart socket.
    This is just a general idea as I don't know specifically the sockets on all the items you've mentioned.
