AV cables for XBOX
Discussion in 'Xbox Forums' started by thelawnet, Sep 12, 2005.
  1. thelawnet
    thelawnet
    Aug 21, 2005
    102
    Hi.
    I currently have crappy old TV plus xbox
    Have RGB/S-video xbox cable, with optical out.
    Tomorrow I'm getting my new 32" Samsung LCD. This has S-video, component plus obviously scart inputs.
    Question: should I buy it a component cable?
    My xbox will be running XBMC with various movies, dvds via dvd region-x.
    No games.
    Will any of these sources deliver resolution above 480i, which I guess I can get from the s-video cable?
    And therefore is there any point in getting the component cable?
    Finally, are the component cables all the same - just a few bits of copper, with little to go wrong, or should I avoid the cheapo ones.
  2. daveon
    daveon
    Mar 31, 2005
    1,635
    Washington
    +126
    As far as I understand it the resolution you get will depend on the media you are playing so if the dvd/game supports 720i that is what you will get if it supports 1080i then you get 1080i.
    I find that I get a better picture from the comp cable than s-video and generally you get little difference using mid range cables as opposed to high end cables, though I would not bother with really cheap cables as I find they wear out quicker as their production is cheaper.
    Hope this helps.
  3. pitchin4eva
    pitchin4eva
    Nov 25, 2003
    325
    +24
    personally I'm buying the vga cable & playing my 360 on my pc monitor
  4. nigelbb
    nigelbb
    Apr 4, 2005
    5,307
    103
    +491
    You need the component cable for HiDef & also to switch the video mode to NTSC. Then you can enable 480p, 720p & 1080i. XBMC does upscale so but DVD-X does not.
    You should get the official Microsoft HiDef pack as it is very decent quality, has the component cables plus optical audio out & I have seen reports of the non-MS cables giving poor picture quality. http://www.divineo.co.uk/cgi-bin/div-uk/xb-of-hidef
  5. chrislad
    chrislad
    May 6, 2005
    5,808
    83
    Rep. of Ireland
    +143
    I heartily approve the official Microsoft Advanced Scart. It made the picture amaziningly clearer on my LCD TV.
  6. thelawnet
    thelawnet
    Aug 21, 2005
    102
    Just a bit resentful of the price they charge. £25 (or more).
    US Amazon ? $20.
    Rip-off the Britons.
    Nice one Microsoft.
  7. Munkey Boy
    Munkey Boy
    Nov 23, 2003
    16,926
    2
    Manchester
    +4,449
    Who charges £25 or more? I've never seen one for more than £19.99. Amazon's UK price is £17.99...
  8. thelawnet
    thelawnet
    Aug 21, 2005
    102
    That's the 'advanced scart'... The one pointed to by nigellbb at divineo is the High definition AV pack.
    Not quite the same I think?
