av amps - why so many connections?
Discussion in 'AV Receivers & Amplifiers' started by jimmy_b, Apr 3, 2005.
  1. jimmy_b
    jimmy_b
    Hi all
    I am thinking of getting myself a surround channel amp. However, all I would connect to it would be my dvd player via a single digital cable and then the speaker connections. I don't need 5 sets of analogue ins and countless video connections/pass throughs. I just want an amp that decodes and amplifies. It seems such a waste to buy an amp with so many inputs/outputs that I simply wouldn't use.
    So, are there are any av amps which simply concentrate on amplifying (rather than cramming in as many possible connections as the unit will allow)? In any price range.
    Also, does anyone out there (apart from commercial users perhaps) who actually need all these extra connections!??
    Jim
  2. Mr Kennedy
    Mr Kennedy
    Feb 28, 2005
    921
    +22
    Well you can add loads to it, Sky+ etc, A Radio output, Playstation, Xbox etc
    I would never have enough of these just in case. And of course you want something that will at least be future proof for a good few years yet.
  3. pjclark1
    pjclark1
    Jul 19, 2004
    4,411
    Thailand
    +271
    usually too many phonos, not enough digital coax and optical, not enough video or component inputs.
    phono sockets cost 5p each or less, removing them from a £400 amp, is not gonna lower the price.
  4. jimmy_b
    jimmy_b
    Thanks for the comments guys. But I still don't really understand....
    HTGUN -
    I can see your point but I don't see how 5 sets of phonos really help here. Surely you still only need digital ins? Given that my set up would be sourced from a PC I'd only need one connection!!. Games - sound output from PC via soundcard's digital out. Internet radio - ditto. Digital music - ditto. DVD player in PC - ditto!
    pjclark1 -
    I am fully with you on the "too many phonos" front but why does an amp need any video ins? Surely it's just for sound processing/amplification isn't it? What do you use video ins for??
    Jimmy
  5. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    12,789
    Somewhere in South Yorkshire
    +4,975
    Errr, yes. (Well, need is perhaps too strong; you don't need a TV, DVD or amp etc. But.....)
    DVD player
    Laserdisc Player
    Cassette deck
    Set Top Box
    VCR
    all routed via the amp - both audio and (except the cassette deck) video.
    Reason? My projector only has one SVideo input and doesn't reproduce sound.
    Oh, and convenience.
  6. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    I think the important point is that jimmy_b is sourcing everything through his computer whilst the majority of us don't even if the computer is connected to the amplifier.
    Why not just use a power amplifier and get your computer to do all of the decoding and volume control as well?
  7. pjclark1
    pjclark1
    Jul 19, 2004
    4,411
    Thailand
    +271
    The video ins are all for upconverting to feed my plasma screen
    that only has 2 inputs. Where else would I connect Sky, Dvd recorder, dvd player, xbox, divx player, etc
    After all, this is an "AV" forum, even if YOU only use the "A" bit.
  8. jimmy_b
    jimmy_b
    You are right, laser disc players etc. do not play a part in my little AV world. A power amp is a possibility but I am worried that I might lose quality by having the DtoA done in the PC. I assume that the DAC in a decent amp would be better than that of a soundcard but maybe I am wrong. Are there many 5 channel power amps anyway?
    I guess a dedicated stereo amp and a cheap second hand 5 channel might be the way forward but I would like to try and reduce the number of components I have.....
    Jimmy
  9. lynx
    lynx
    Jan 20, 2002
    4,633
    It always rains.
    +301
    I don't know of an amp to suit your needs, however if you need a new mobile phone this may suit...http://www.silverphone.co.uk ;) :D
  10. jimmy_b
    jimmy_b
    you sarcastic b*gger :)
