AV Amp with Component Switching.
Discussion in 'AV Receivers & Amplifiers' started by whiteswan, Nov 13, 2004.
  1. whiteswan
    whiteswan
    Dec 9, 2002
    944
    Oldham
    +55
    What is the cheapest av amp with component switching (ie i can put say 2 component devices into the amp and take 1 component out to a display) - also do any have scart inputs/outputs as well?
    Which do u recommend?
    Dave, Oldham.
  2. pragmatic
    pragmatic
    Nov 9, 2004
    12,150
    +1,647
    The only amps with Scart in are expensive marantz, but they only have one in one out and no component. So i'm not sure what the point of it is really.
  3. whiteswan
    whiteswan
    Dec 9, 2002
    944
    Oldham
    +55
    Okay forget about the scart - what about component?
    Dave
  4. Mandel
    Mandel
    My Yamaha HTR-5640 (aka RX-V640) has two component inputs and one component output as do most on this range. I got mine at £180 on special offer and I'm sure you can pick up a 440/450 for under £200 no problem.
  5. Dfour
    Dfour
    Jan 19, 2004
    4,088
    71
    Bracknell
    +86
    I take it you only want componant switching and not up conversion IE. s-vhs to componant?? Look at richer sounds for good prices on the Yamaha 640.
  6. whiteswan
    whiteswan
    Dec 9, 2002
    944
    Oldham
    +55
    Aha now up conversion sounds good...........cheapest available?
    Dave
  7. clarky78
    clarky78
    Nov 8, 2004
    1,845
    Helsinki, Finland
    +40
    my yamaha 750se does video upconversion to component level. Available from around £400 quid if you shop about. Sounds cracking too :) :)
  8. whiteswan
    whiteswan
    Dec 9, 2002
    944
    Oldham
    +55
    Been looking at that Clark - found it for £350.00 delivered online.........if the component in has prog scan - I assume u dont lose this?
    Also how many svideo in - component in etc?
    Dave, Oldham.
  9. Dfour
    Dfour
    Jan 19, 2004
    4,088
    71
    Bracknell
    +86
    Have a look at www.avland.co.uk as they have the most thurough list of the componants on amps than most retailers or alternativly look at the yamaha website for the info. I also believe the denon 2105 also has up conversion.
  10. clarky78
    clarky78
    Nov 8, 2004
    1,845
    Helsinki, Finland
    +40
    2105 has up conversion, but only to s-video i believe. 2805 has component up.
    As fpr the progressive scan, i can't say as at the moment i dont use the component switching, but i see no reason why you should lose it.
