AV Amp with aptX headphone stage
Discussion in 'AV Receivers & Amplifiers' started by sygad, Apr 1, 2016.
  1. sygad
    sygad
    Mar 24, 2010
    2
    4
    H
    I've recently purchased the Sennheiser Momentum II's, which are amazing and I tried searching for any AV amp that has a bluetooth headphone stage with aptX so I can use the headphones in the lounge.....absolutely no success.
    Has anyone got any amp recommendations?
  2. Longy00000
    Longy00000
    Aug 19, 2008
    1,266
    England
    +476
    Yamaha musiccast system allows for blutooth headphones to be connected. Not sure if it's an apt x variant or not though.
    So any yamaha amp with musiccast feature will certainly connect to your headphones just not sure what type of blutooth is engaged that's all.
  3. sounddog
    sounddog
    Dec 11, 2002
    3,445
    107
    Leicestershire, UK
    +480
    I'm slightly confused what you're looking for.
    Aren't Sennheiser Momentum II wired headphones? aptX is a CODEC used over Bluetooth for wireless headphones.
    If they are Wireless headphones, then you might need to use an external Bluetooth transmitter.
  4. Longy00000
    Longy00000
    Aug 19, 2008
    1,266
    England
    +476
    I think they recently launched a wireless version with noise cancelling.
  5. Jules
    Jules
    Oct 11, 2000
    5,613
    134
    +1,092
    My recently acquired Yamaha RX-A3050 will connect to my Sony Bluetooth headphones no problem.
    It has bluetooth in and out, but I don't think its output is aptX. Sounds ok though.
    Not sure if it applies to all of Yamaha's 2016 AV Receiver line up, but I'd wager bluetooth output will definitely be included on all 2016 Aventage models.
