AV AMP with 2 Sets of Component Outs ?
Discussion in 'AV Receivers & Amplifiers' started by loonatic, Mar 28, 2003.
  1. loonatic
    loonatic
    Jan 4, 2003
    1,925
    41
    Springwell Village, Gateshead
    +16
    Does anyone know if anyone makes an amp with at least 2, preferably 3, component inputs and 2 outputs - either selective or both active ?
    The reason I ask is that I'd like to connect my equipment - DVD, Sky+ - to both my Plasma and my PJ.
    If not does anyone have any other options.
    Cheers, Lee
  2. S H A D O
    S H A D O
    Mar 16, 2001
    10,369
    United Kingdom
    +1,737
    The Denon A1SR, A1SE and A11SR all have three sets of Component Inputs and one set of Component Outputs. All with video switching between sources.
    The 3802 also has two sets of inputs and one output. As does the newer 3803 but its are assignable.
  3. Flimber
    Flimber
    Sep 22, 2002
    13,672
    Yorkshire
    +4,476
    Bloke wants two on the way out, Jase. Possibly, some funky US pre-amp has this. Else, a splitter of some sort.
    Mike.
  4. S H A D O
    S H A D O
    Mar 16, 2001
    10,369
    United Kingdom
    +1,737
    Oops!:eek: Need some coffee, not awake yet. :laugh: Don´t know of any that have two outputs, must be a splitter available somewhere.:confused:
  5. S H A D O
    S H A D O
    Mar 16, 2001
    10,369
    United Kingdom
    +1,737
  6. Flimber
    Flimber
    Sep 22, 2002
    13,672
    Yorkshire
    +4,476
    If someone was happy to halve their signal like that then RCA splitters at the amp outlets would do the trick too :D
    Purists :thumbsdow
    Mike.
  7. S H A D O
    S H A D O
    Mar 16, 2001
    10,369
    United Kingdom
    +1,737
    All part of the fun of experimentation.:laugh:
  8. John Dawson
    John Dawson
    Jan 16, 2001
    852
    43
    Cambridge, UK
    +112
    You will not be able to use a splitter cable on the video outputs as each display device is 75 ohms and two in parallel makes 37.5 ohms, halving all video amplitudes. I am pretty sure that will be too much to correct downstream with the contrast controls on the displays.
    If you want two sets of video outputs you will need to buy some kind of active box to do this if there is any such thing outside the realms of professional video equipment.
    HTH.
    John Dawson (Arcam)
  9. JGM
    JGM
    Dec 13, 2002
    946
    46
    Alderley Edge
    +218
    One solution is to add a Quadscan Pro. This has two sets of component inputs but the second set can be assigned as an output pass-through of the first set. I presume the Centerstage does similarly.
    Hence you could have the scaled output to your PJ and the pass-through to your plasma or vice versa.
    Sorry it's not a cheaper option.
    John
  10. Flimber
    Flimber
    Sep 22, 2002
    13,672
    Yorkshire
    +4,476
    Naturally, a splitter is really only goint to be a bad idea if you need both outputs simultaneously.
    Mike.
  11. sounddog
    sounddog
    Dec 11, 2002
    3,437
    107
    Leicestershire, UK
    +477
    Can you not use a 3ch. switch box in reverse as it were - or do you need both outputs simultaneously?
