Av Amp to laptop
steve k
Can anyone tell me if its posable to connect my laptop to the pioneer ASA-AX10i so i can play my music files of the laptop :confused:
buns
im sure it is! You need a minijack (headphone type connector) to 2 phonos more likely than not. These are available at all the bigger cable suppliers for next to nothing for a cheap one...... try www.lektropacks.com
ad
steve k
if i connect the laptop with minijack it will only give me stereo,
can i connect the loptop with the i-link the Pioneer AX10i has 2 i-link connectors, if so would this give me the abilaty to play movie's of my laptop with 5.1 surrond
J
Jimmysil
The other alternative would be to get a external usb sound card and use digital output on the sound card.
I use to do this with my sony laptop using a creative lab exitgy.
Regards
James
Dave777
My laptop has SPDIF output on one of the 3.5mm audio jacks (Toshiba 5100) and I've never managed to get this to output digital sound to my AX5i. I'm using the correct leads (3.5mm to phono plug to the co-ax digital input on amp). I've tried using WinDVD to send a DVD sound but no luck. I assume its a setting on the laptop but Toshiba's manual is useless.
Any ideas which might help Steve or I
Dave
buns
have you tried looking in start-control panel-sounds and audio devices for something useful?
ad
Dave777
Yes!!
It's driving me batty!
Dave
buns
doh, sorry! I might be able to work it out if I had it sat in front of me..... but otherwise I cant be much help!
ad
steve k
i got myself a usb Creative labs sound blaster Audigy2 NX yesterday and installed it on my laptop, the sound diff waz fantastic even when i used my headphones tried it with the Matrix.
This little sound system even comes with a remote, only thing i could not do is use window media player ,
Any ideas James
65-inch LG C1 Review coming soon to AVForums
