av amp / speaker match
Discussion in 'AV Receivers & Amplifiers' started by lilox, Jun 10, 2009.
  1. lilox
    lilox
    Apr 11, 2007
    3
    thinking of going with the b&w 685 with denon 1910 when it comes out, I have a kef psw 1000 sub
    I will build the rest of the system probably with a b&w center and maybe some kef rears,
    main concern is, are the denon 1910, psw 1000 and 685's a good match, i'll sort the rest out later
    sources are sky hd, xbox 360 elite, wii, pioneer DVD, but will probably upgrade to a blu ray player, and my ipod
    possible future sourced - marantz sacd, pro-ject debut 3 turntable,
    i know the connections are there, just wondering on the balance between the speakers :)
  2. lilox
    lilox
    Apr 11, 2007
    3
    i have listened to the 685's but not with an AV amp, I am waiting to hear them with a 1909 /1910, i havn't trialed the kef iq30's yet which are my other choice (prefer the look)
    my other choice for an av amp would be the sony dn1000
    i am aware these amps arnt out yet, but would assume similarities to be very close to the 1909 and the 2400es
  3. dante01
    dante01
    Mar 5, 2009
    45,582
    +10,841
    The Sony wont be the best match for the B&W speakers. If you opt for the Sony receiver, the KEF speakers would be a better match, either that or something by Tannoy.
    I'd personally prefer the Denon and B&W combo.
  4. PSM1
    PSM1
    Dec 20, 2008
    26,279
    +5,432
    Try and get a demo of the amp you want in your house. Then you can see if it is a match that you like.
