AV Amp for £350/£400
Discussion in 'AV Receivers & Amplifiers' started by Vinesh, Dec 24, 2002.
  1. Vinesh
    Vinesh
    Dec 23, 2002
    776
    28
    +31
    i currenty have a Sony STR-DB930 Av Amp.
    I am going to sell this and I will have around £400 to spend on a new amp.
    Which amp would you guys/gals recommend?
    Sony 1080, Marantz, Denon??
    I want a amp with 6.1.
    Please help me decide
  2. wilber
    wilber
    Sep 29, 2002
    1,970
    +30
    try using the search facility. this question gets asked weekly.
    current faves in this approximate range:
    Marantz 4300/5300
    Yamaha 630
    Denon 1803
  3. Vinesh
    Vinesh
    Dec 23, 2002
    776
    28
    +31
  4. JSW
    JSW
    Feb 21, 2002
    4,283
    Staffs
    +333
    Look in the Hardware fs section ;)
  5. Silent Fly
    Silent Fly
    Wilber,
    We are in a similar situation. I will buy a 6.1 receiver in the January and after months I decided for the Marantz 5300. I will use it 50% for music, 50% for DVD/home cinema.
    Nothing wrong with the other amps (they are all very good actually) but personally I considered the following:
    - I excluded the Yamaha 630 because it has limited management of the delays/distances of the speakers.
    - Denon 1803 does not seam to be that good with music.
    - Marantz 4300/5300 (apparently) are pretty good with music.
    - Marantz 5300 is slightly more powerful, it has on-screen display and more in/outs.
    - Marantz 5300 is quite popular @ avforums
    If I had the money I would probably buy the new Denon AVR-3803 but £900 is definitely too much for by budget.
    Silent Fly
