Automated TV cabinets
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by Luc, Nov 12, 2000.
  1. Luc
    Luc
    Aug 7, 2000
    420
    Does anyone know where in the UK to buy TV motorised TV cabinets, ie ones that drop the TV down into the cabinet with a motorised system? The cheapest one i've found is this one --> http://the-office.com/summerlift/liftbox.htm but at $545 dollars, i'm sure there must be cheaper alternatives, and ones that are available in the UK.
  2. Luc
    Luc
    Aug 7, 2000
    420
    Thanx man, that's exactly what i'm looking for. I KNEW $3000 was excessive.
  3. Dodgey
    Dodgey
    I'll post you a phone number for a catalogue tomorrow (haffael, or something like that)
    My g/friend is an interior designer and has had one of these built for a client.
    Youcan just buy the scissor jack mechanism with motors and switches etc. for about £150 and then modify your own box.
  4. Dodgey
    Dodgey
    OK. Here's the rub.
    The Company is called Hafele (there should be accents above the "e"'s but I can't be bothered to find out how to do it).
    They are a TRADE ONLY catalogue. They supply every widget imaginable, from scissor lifts to kitchen towel rails to brackets that let a TV come out of a shelf and rotate etc. etc.
    Their number (for a catalogue) is 01788 542020. Their email address is info@hafele.co.uk
    You will obviously need to send them a letterhead or such like (I'm sure you can manage [​IMG] ) to prove you are "trade".
    Good luck
    Have fun!!
    p.s. It's a HUGE catalogue with every obscure thing in it you could think of. A veritable gold mine.
