AutoGK Problem - Help!
Discussion in 'Desktop & Laptop Computers Forum' started by PannyAdams, Jun 14, 2005.
  1. PannyAdams
    PannyAdams
    Dec 5, 2004
    661
    Epsom
    +5
    A while ago, I ripped my DVDs to my HTPC (Using DVD Shrink). However, space is running low so I decided to convert a load of my DVDs to Divx to save on space. I thought I'd start with autoGK as it is supposed to be the easiest but have fallen at the first hurdle, I point it at my Video TS directory but it gives me an error saying it can't find the Stream Info file......Help :lease:
    Or is there any easier software to convert them - especially software that will queue them up so I run batches over night.
    Panny
  2. Rambles
    Rambles
    Jul 14, 2004
    7,707
    UK
    +909
    I use DVX.
    You have to let it automatically download the extra plug ins, but there is an inbuilt tutorial which walks you through the settings, I have good results encoding to Xvid
