Auto Widescreen switching?
Discussion in 'Blu-ray & DVD Players & Recorders' started by cbemoore, Jun 18, 2003.
  1. cbemoore
    cbemoore
    May 16, 2002
    1,220
    38
    Eastleigh
    +16
    My widescreen TV happily switches automatically between 16:9 and 4:3 modes when connected to my DTT receiver.
    But when I'm using my DVD player, the TV stays in 4:3 mode even when its playing a widescreen DVD. I have to manually change the aspect ratio on the TV to make it display correctly. I thought it was a problem with my DVD player, so I borrowed a friend's DVD player to test. Unfortunately that has exactly the same problem.
    I've tested using RGB Scart (to test Scart Pin 8 WSS), and via S-Video (to test Line 23 WSS).
    So is this a problem with the DVD players I've tested? Or do DVD players simply not support auto widescreen switching?
    Chris
  2. stubags
    stubags
    They do support auto widescreen switching.
    There are several things that I can think of. Firstly, I would think of your scart lead but that's probably not the culprit. Secondly, is your dvd player setup to output to a widescreen tv in its options as otherwise it will not switch. Thirdly, is your tv receptive to switching on every AV input. Mine definitely isn't receptive to it except for on AV1 and AV2, AV3 is deaf to this switching. Lastly it will depend on the dvd that you're playing, but these days most of them switch to widescreen. Even more lastly, your tv has to be in a mode that allows it to switch, if you've got it in a particular aspect mode, not automatic, then it might not switch.
    Hope this helps.
  3. cbemoore
    cbemoore
    May 16, 2002
    1,220
    38
    Eastleigh
    +16
    I'm using the same scart as I use with my DTT box, so I'm fairly sure that's not the problem.
    Yes, I've set the DVD to 16:9
    I'm using AV1, which switches fine with my DTT box.
    Could be!! I tried it with 2 DVDs, but I'll try a few more tonight.
    Yes, its definitely in automatic mode.
    Thanks for your help - looks like I need to try it with some more DVDs!
    Chris
  4. gizlaroc
    gizlaroc
    Jul 26, 2001
    8,698
    Norwich
    +606
    I havent bought any region 2 discs for years but from memory I think that region 2 do switch but region 1 doesnt.
    could be talking ****e, but that rings a bell.
  5. nathan_silly
    nathan_silly
    Yes you're talking ****e! :)
    If you have a multi-region DVD player but using SCART with widescreen capability (cable, DVD player & TV) then the Region/format is irreverent.
  6. gizlaroc
    gizlaroc
    Jul 26, 2001
    8,698
    Norwich
    +606
    None of my region 1 discs switch the tv to 16:9 mode, not with a pioneer 737 or a panasonic, via scart or s-video.
    I thought that the disc has to have wss encoded into it to tell it to switch ????
  7. SOUNDSTYLE
    SOUNDSTYLE
    Oct 4, 2002
    1,194
    48
    +34
    You don't have an older Philips tv do you?
    I had the same problem where widescreen dvds would not switch to 'wide' automatically, even though terrestrial C4 would.
    Got a Sony tv now, and have no problems at all.
  8. cbemoore
    cbemoore
    May 16, 2002
    1,220
    38
    Eastleigh
    +16
    Yes, I do actually have an older Philips TV!! (32PW6332). I guess that must be the problem!
    I think both the DTT box and analogue Ch4 use Line 23 WSS, which works fine. Maybe DVD players use Scart pin 8 WSS, and that's not supported by the Philips TV?
    Anyway, its nice to know its not a problem with my DVD player. Thanks!
    :clap:
  9. Kevo
    Kevo
    Aug 23, 2001
    5,354
    Manchester
    +144
    No you're not talking ****e!
    None of my R1 WS DVDs auto switch either and that's using RGB SCART on ext1 (AV1).
  10. gizlaroc
    gizlaroc
    Jul 26, 2001
    8,698
    Norwich
    +606
    ahh nice one, I was trying to rack my brains thinking what region 2 disc I had to try and couldn't think of one.
    there were virtually no 16:9 tv sets out apart form the pioneer elite ranges when the us dvd players were first released.
    back then we could laugh at their inferior system, oooh how times change :(
  11. cybersoga
    cybersoga
    Apr 7, 2002
    1,628
    48
    UK
    +25
    I have a Sony DVD player and a Sony TV. All my anamorphic widescreen DVDs, whether they are R1 or R2, automaticly switch the TV to WIDE mode. 4:3 DVD's such as TV shows put the TV into 4:3 mode or SMART mode depending what I last left it on. Letterbox widescreen dvd's (non anamorphic) don't auto switch (The TV sees them as 4:3), I have to manually set the TV to ZOOM mode.
    There are 2 ways that TVs can be told to switch aspect ratio, the first is by applying different voltages on pin 8 of the scart lead, and the other, newer and more preferable way is by reading line 23 WSS http://www.intersil.com/data/an/an9716.pdf which is part of the picture. Most wide-screen sources such as STBs and DVD players do not produce this signal, but Sony kit does and so does my Netgem I-Player set top box connected via component.
  12. Matt F
    Matt F
    Jul 18, 2000
    900
    Chester, UK
    +4
    Well, I have the Philips 32PW6322 (the NICAM only 32") and it auto widescreen switches on DVD's and, get this, this is even just using an s-video - SCART lead (i.e. s-video out on DVD player to EXT-2 YC SCART on the TV).
    Matt.
  13. cybersoga
    cybersoga
    Apr 7, 2002
    1,628
    48
    UK
    +25
    Both your TV and DVD player must be Line 23 WSS complient then.
  14. cbemoore
    cbemoore
    May 16, 2002
    1,220
    38
    Eastleigh
    +16
    Which confirms what I suspected.
    I reckon my Philips TV only supports line 23 WSS, and not Pin 8 scart switching. Whereas the DVD is the other way around.
    Chris
  15. gizlaroc
    gizlaroc
    Jul 26, 2001
    8,698
    Norwich
    +606
    my tv is a philips and although it doesnt switch with region 1 dvds it does support wss via pin 8, as I have made loads of cables up for various consoles and always add voltage to pin 8 so it switches to 16:9 mode.
  16. AOD
    AOD
    Feb 7, 2001
    707
    London
    +4
    Bit of a pain isn't it, to have to "match" your TV and DVD player?
    My DVD player (a Toshiba 100 or 110, can't recall which) will aspect switch my 32" Sony, and this is via S-Video routed thru my Tag. Guess I'm lucky in that respect.
    Of course being connected in this way does mean that the TV won't switch sources automatically, but I can at least map an AV input to a channel number so when I want to watch a DVD I can directly select the "channel" or include it in a macro of some sort.
  17. puddleduck
    puddleduck
    Jan 24, 2003
    1,814
    48
    Lake District, near as dammit
    +50
    With my previous Pioneer 737, if the TV was in 4:3 mode, and I played a 16:9 disk, it didn't auto-switch.
    Auto-switching works as expected on my Philips 963SA.
