auto switch
Discussion in 'Subwoofers' started by reevesy, May 19, 2005.
  1. reevesy
    reevesy
    Feb 20, 2005
    5,051
    +1,196
    hi all,
    can anyone out there tell a thicket how to use the auto switch on my kef psw 3000?
    i know when the sub is switched over to auto its meant to switch it'self off after 10 mins of being idle when finished with but the trouble is once i've flicked the selector over to auto i cant seem to turn the sub on.
    it wont switch on via the remote and i tried turning everything on thinking it might detect a signal but no joy.
    i have'nt bother to use it since i got the sub but just lately after a few drinky poos i've been trotting off to bed fogetting to switch it off so i thought it might come in handy if i started using it.any pointers?
  2. chedmaster
    chedmaster
    Jan 29, 2005
    2,654
    68
    +28
    apparantely its ok to leave it on all the time, don't hold me to that, just something i picked up on these forums!
  3. reevesy
    reevesy
    Feb 20, 2005
    5,051
    +1,196
    yep i had heard the same, low power whilst on stand-by and idle,unlike a tv but it'll still be nice to know its off.saying that i'd probably lie awake until i came back downstairs and checked anyway.
  4. spuddler
    spuddler
    Oct 28, 2004
    385
    28
    +29
    Hi,if the low level input signal to the subwoofer is too low auto function may not work.Either increase the gain on your amp(ie volume)which will increase low level input signal or if you can increase the gain for the subwoofer in your amp setting's this will increase LLIS to your sub(Auto should work then)the volume of your sub may be too high then,so turn down the gain on your Sub to compensate.Hope this will work for you.
    BOB
  5. Hairy Herman
    Hairy Herman
    Also if your subwoofer has two (L+R) inputs, try buying a y splitter to connect one lead to both sockets, as some subwoofers have a gain of 6db with this, may make it notice it a bit more!
  6. Hairy Herman
    Hairy Herman
  7. reevesy
    reevesy
    Feb 20, 2005
    5,051
    +1,196
    cheers chaps
    got a y splitter fitted,i'll have to try adjusting settings as suggested.at the mo the volume on the sub is fairly low (3 led blocks) working on less is more,i'll have a fiddle later.
