Auto switch ?
Discussion in 'Home Cinema Speakers' started by LCDRulz, Mar 15, 2005.
  1. LCDRulz
    LCDRulz
    Anyone know of a way of sharing one pair of speakers between two sources where the switchover is automatic ?
    TIA
    Roy
  2. davehk
    davehk
    Oct 17, 2003
    713
    28
    London
    +45
    What selection criteria? ie how would the unit know when to switch?
  3. LCDRulz
    LCDRulz
    The switch should detect the active source and switch the speakers to that source.
    If both sources are active then the switch should not changeover from the last selection and indicate with an led that both sources are active. Likewise if both sources are inactive.
    Anyone seen such a switch?
    tia
    Roy
  4. davehk
    davehk
    Oct 17, 2003
    713
    28
    London
    +45
    Hmm - what level of signal defines active? Should it be adjustable? what sort of hold time is needed to prevent unwanted switching? - most music has periods of silence (depending on what you listen to, of course), radio stations certainly do.
