Auto switch to HDMI input on Tosh 32WL56
Discussion in 'LCD & LED LCD TVs Forum' started by Tycho, Jun 15, 2005.
Tags:
  1. Tycho
    Tycho
    I have a Toshiba 32WL56 and a Samsung 850 connected by HDMI. When I had these connected by scart, the TV used to switch to DVD source when the DVD player was switched on. With the HDMI connection, this doesn't happen and I have to select it manually.
    Is this normal? It isn't a show stopper but is a bit of a pain.
  2. ener1
    ener1
    Aug 9, 2004
    1,377
    48
    +46
    I also have a Toshiba 32WL56 and i think you can only switch it manually. The scart sends a little electrical message which makes the TV select the correct channel. Well thats what i understand of it....i might be wrong ofcourse :rolleyes:
    Ener1
  3. JuMpPa
    JuMpPa
    I currently dont own a LCD-TV, but its stated in the HDMI standard that devices can use HPD (Hot Plug) signal to to "wake up".
    I dont know is this feature used at all, but what I can see from your dilemma I think it isnt in common use :)
    Like ener1 sayd Scart has a "wake up"-pin that tells the receiving end to take notice and switch to receive the signal.
    I think u should try to live with the "problem" :)
  4. Tycho
    Tycho
    Cheers for the replies guys, it is only a nuisance rather than a big pain so I'll live with it.
