Auto standby issue on sub woofer
Chris B
Joined
Oct 9, 2008
Messages
13
Reaction score
Points
3
I have recently purchased a Onkyo LSV 501 package.
Apart from an issue with getting the sound from the TV to to speakers which has been addressed elsewhere in this forum and highlights its a TV issue, i am very pleased....however.
Can someone explain what i can do to stop the Sub-woofer "switching off" as in going into standby mode.
I have read the RTFM and it states it will do this if it doesnt get sufficient bass, however even with the best action soundtrack and the setting at subwoofer +12, it goes into standby mode after a few minutes. Unplug the jack and replug it in and hey presto its great. Light goes from red to blue, all is well for a few minutes.
Please help this newbie out.
Chris
It sounds like you're not sending enough signal from the amp.
If unplugging/replugging the jack restarts it, it's probably because you are causing a surge as you do so. Don't keep doing that, you might blow something mate :nono:
Have you set the speakers to small with a fairly high crossover?
I can only suggest you re-read the manual, pages 55-57, as you might have missed something.
Badger 0-0
Belated thanks for your advice and help. Works a treat now. One very happy user !
Chris
StormAudio ISR Fusion 20 AV Receiver - review coming soon #HomeCinema #Amplifier #VideoShort
Back
