Auto-Standby and Anytime - can't find them?
interbear
Hi all - new Sky HD box installed earlier this week.
Try as I might I can't find any reference to either the Auto Standby feature or Anytime TV?
The engineers did a software update when they installed the box.
Any guidance appreciated. Thanks.
ataribaby
hi ther in answer to your questions,you will find these features in your services menu auto standby is in the sky plus menu and anytime is in the anytime tv set up hope this helps!
sol_prior
Also it can take several days for the Anytime update to download - if your HD channels are accessed via the red button in the TV guide then the update hasn't happened yet.
For some reason the software downloaded when the engineers do a forced update isn't the Anytime version.
interbear
Thanks both - clearly Anytime has not yet arrived chez moi.
I'll check the sky+ set up tonight to find the auto-standby.
JimmyT
I might be wrong but i think the auto standby option came in the same software drop as Anytime so you may have to wait for both.
S
sminc
Leave your system in standby overnight, it might be coincidence but I got my download / upgrade when I did that.
