Auto-insert DVD playback not working, pls help.
Discussion in 'Desktop & Laptop Computers Forum' started by Rob.Screene, Apr 27, 2003.
  1. Rob.Screene
    Rob.Screene
    Sep 29, 2001
    1,124
    Berks, England
    +45
    Using WinME and TheaterTek 1.2 inserting a DVD used to open TheaterTek and start the movie.
    I did a full clean and re-build for TheaterTek 1.5 and it doesn't work any more.
    As before, I run RegionKiller and DVDautoRefresh.
    DVDautoRefesh notices the disc insert and sets resolution correctly as before, just now TheaterTek doesn't start. I think it does sometimes, say one time in 10, but I couldn't be sure.
    Any help appreciated.
    regards,
    Rob.
  2. Tim Cooper
    Tim Cooper
    Sep 20, 2000
    2,773
    71
    Laindon Essex
    +96
    Hi Rob,
    Have you tried disabling region killer? worth a try.... & upgrade to the latest killer.
    Do you use Girder....if yes try upgrading that as well sounds like the set-up has got it's knickers in a twist.
    You could also upgrade to a decent OS:devil:
    Tim
  3. Rob.Screene
    Rob.Screene
    Sep 29, 2001
    1,124
    Berks, England
    +45
    Thanks Tim!
    Disable region killer sounds like a smart test. I'm pondering if I'll re-try XP again, I still have an unregistered Home copy from the last time I tried it, but DX9 and Cat2.5 and a few TT revisions have been released since.
    Any other ideas?
    Rob.
  4. Tim Cooper
    Tim Cooper
    Sep 20, 2000
    2,773
    71
    Laindon Essex
    +96
    Hi Rob,
    I was a diehard windows 98se, but now XP has matured with regards to drivers etc i'll never go back, not even to win 2k, got mine running real smooth with all the latest goodies plus re-clock,it's running so smooth i'm bored with it ;)
    Go on, do the transition, i can help you...trust me;)
    Cheers m8.
    Tim:smashin:
