Hi y'all. I have had a Yammy AX-1 since last November. ( I paid £1500 for it then ). It developed a fault with the back left surround channel. So I sent it back to the shop where I got it from & they sent it back to Yamaha to be fixed. This took exactly 2 weeks. Now it won't automatically select Dolby EX. It does,though,select DTS ES. I have checked the set up & it is set to auto EX/ES 'ON'. Has my Yammy developed a new fault? Cheers, Neil
Neil, “Now it won't automatically select Dolby EX. It does,though,select DTS ES. I have checked the set up & it is set to auto EX/ES 'ON'. Has my Yammy developed a new fault?” No hardware can currently auto-detect EX encoded material, not because of the hardware itself, but because there aren't any EX flags in the Dolby Digital bitstream (Dolby have only just released an encoder revision to facilitate EX flags). As your Yamaha wouldn't auto-detect EX material before, it won't do it now. ES can be automatically detected, depending on software. ‘Chicken Run' carries an ES flag, but ‘Gladiator' does not (both region 2). You'll have to manually select the pseudo-EX mode (6.1 Matrix) on your Yamaha. Stuart M. Robinson SMR Group – http://www.smr-group.co.uk/
