Authoring problem
Discussion in 'Blu-ray & DVD Players & Recorders' started by Northerner, May 14, 2004.
  1. Northerner
    Northerner
    Aug 12, 2003
    112
    19
    The land where The Macallan is distilled
    Recorded a film (Last Of The Mohicans) the other night, on DVD-RW. Used TPMG Author to transfer to the HDD. It located the DVD_RTAV file OK but about half way through transfer, I get a "stream error" message. That's all it says - no other details. I've tried this transfer 3 times and get the same error each time
    Any clues anybody :confused:
  2. puddleduck
    puddleduck
    Jan 24, 2003
    1,859
    48
    Lake District, near as dammit
    +59
    Try copying the DVD_RTAV file onto your hard drive. If this copy fails, it means you've got an error on the disk.
    Occasionally I've had CRC errors and the PC can't read the disk, so you'll need to re-format it on your recorder, if this is the case.
