Aussie PS2
Discussion in 'Playstation Forums' started by Shoka, Jan 10, 2002.
  1. Shoka
    Shoka
    Jan 10, 2002
    4,330
    Surrey
    +238
    :confused: I have got an Aussie PS2 (region 4, I presume) does anyone know if they are region 4 or region 2, I havent used it yet?
  2. Mr.D
    Mr.D
    Jul 14, 2000
    11,190
    +1,231
    you tell us!
  3. graham.myers
    graham.myers
    I would have expected region 4
  4. Shoka
    Shoka
    Jan 10, 2002
    4,330
    Surrey
    +238
    What about UK games, do you reckon they will work?
  5. graham.myers
    graham.myers
    there has been another thread which says oz games will work as they are PAL as is Europe. Its just DVDs as they only have region coding. Games do not.
    similarly UK purchased games should therefore work on an oz console.
  6. Shoka
    Shoka
    Jan 10, 2002
    4,330
    Surrey
    +238
    Wicked, looks like I'll have to get one of those things you plug into the memory card slot, that makes it amulti region player.
  7. othello
    othello
    Oct 9, 2001
    147
    16
    england
    i just been over in aussie.there games work fine on my ps2.both are pal.so games wise you will be o.k. as for dvd`s tho you will need a dvd region key.the one you said which plugs into the memory port.you get a cd to put in ever time you want to watch a disc which wont be region 4.i got mine in aussie so my nephew could watch films.also the games over there where cheaper.got wipeout fusion for less than 30 quid :) hope that helps m8.
