Question AURALEX ACOUSTICS SUBDUDE II ISOLATION RISER FOR SUB WOOFERS Home studio accessories Speakers pads
Discussion in 'Subwoofers' started by simonblue, Nov 8, 2018.
  1. simonblue
    simonblue
    Jan 29, 2006
    19,238
    163
    +8,632
    Anybody using theses ?,would they work with downward firing Sub ? :)
  2. paulst10
    paulst10
    Dec 16, 2004
    12,435
    Essex
    +1,838
    I had two for my dual XXLS400 subs. On suspended floor yes, on concrete, probably not so much, although you could probably make your own for about £10 as it's basically a bit of MDF wrapped in fabric with foam on the bottom :)
  3. meagabyte
    meagabyte
    Jun 2, 2015
    695
    2
    46
    Worcester
    +149
    i was thinking this this morning.
    Ive gone from a forward firing sub to a down firing sub and the difference is rather disappointing.
    Ive tried slightly different locations and tinkering but its just not the same. My conclusion is that its firing down into a floor with a ton of laminate and underlay thats somehow absorbing the sound.
  4. Gasp3621
    Gasp3621
    Jan 16, 2014
    1,438
    116
    +687
    Move it behind your couch laying on floor! ;):laugh: Should be felt more!
    [​IMG]
  5. meagabyte
    meagabyte
    Jun 2, 2015
    695
    2
    46
    Worcester
    +149
    LOL i wish that was an option. but couch is right up against the back wall. The curse of the UK small lounges. So does putting a square chunk of wood or even a paving slab under these help?
    Gone from PB2000 to a PC2000 like yours
  6. simonblue
    simonblue
    Jan 29, 2006
    19,238
    163
    +8,632
    I tried a lot of front firing subs years ago,but due to the only place i could place them (by an old window frame) they used to rattle the frame like hell.
    So by chance got a couple of Rel Storm subs,which works really well in my flat,but decided to downside them a bit,so went for the smaller T5i,they work great,but was wondering if the risers would help,stopping some of the sound from going downstair,i live in a flat :(:)
