audyssey... tripod??
talkinloud
hi all, just been trawling through the audyssey threads and its advised that a tripod be used for the set up etc, can someone elaborate, is sitting in the listening position holding the mike not advisable... thanks...
sol_prior
No - the microphone should ideally be where your head is when sitting in position - if you are there then the microphone can't be. The microphone is sensitive to ambient noise too, including your breathing.
The system compensates for the room set up - so moving the furniture is out too - all in all a tripod is the best solution.
LicensedTaximan
Ditto
