TB Rich
I've just finished doing a second play through now I have XT32 and the Audyssey App - I've got 3 different curves, interested to know which one most people may choose? - Is this broadly how other people are setting up their systems too?
Red line is the as-is XT32 output, so mains were set as large/full range, sub level reported at -10.5dB, reference curve, etc (although I did turn off midrange compensation and all the dynamic eq/volume malarky).
Purple line was using the same XT32 results, but changed from reference to flat, plus I set the mains to small. Sub was increased from -10.5dB to -6.5dB.
I experimented with different crossover points, noting that 80hz created a massive hole in the response, whereas 90hz and 100hz fixed that. - The sweep above is at 100hz. (I'm hoping it won't be noticeable/directional this high).
Green line, this was copied from the Purple with the adjusted settings - and then started to mess with the Audyssey app curves. Added in a slight lift at 30hz and drop at 65hz - to create more of a slope. My reasoning being that as bass gets lower you need progressively more volume to hear it. Lastly I also pulled the Audyssey curtain back to 500hz for all speakers.
Cheers!
Cheers!
