Auditioning a DLP Projector
Discussion in 'Projectors, Screens & Video Processors' started by theendisnye, Dec 30, 2004.
  1. theendisnye
    theendisnye
    Oct 11, 2004
    63
    I am auditioning a DLP projector the infocus 5700 tomorrow (I need a long throw lens and it is one of the few arounnd) I haven't seen a projector before in use and wanted to know what I should be looking for (rainbows!!!) and what DVDs / scenes (or types of scenes) were the best to audition it with?
    Steve
  2. inzaman
    inzaman
    Dec 16, 2002
    7,887
    Derby
    +939
    I think if you are prone to rainbows you should see them straight away. I did not see them but did get eye strain after about 30 minutes of viewing.
    The best types of scenes imo that highlight the rainbows are white writing with a dark background.
    You should also take any family members with you if they too are going to be watching the pj. I would though just take your favourite films (or selection) and if they are fine then just purchase and enjoy.
    I dont know how new the 5700 pj is but with the newer ones i.e 4805 onwards i havent had any problems at all with DLP, no rainbows or eyestrain.
  3. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
  4. SuperSportBilly
    SuperSportBilly
    May 18, 2004
    2,116
    83
    +407
    I am looking for a projector in that same price range.
    I have my eye on the Optoma H57 - similar spec to the 5700 - same resolution. The Optoma H57 has (on paper) a higher contrast level. It is also cheaper at £1799.
    I am waiting to view one.
    I am shortly due to view a 4805 & 5700 to compare to my Sanyo Z1.
    I took the Z1 to a demo of the Sony Hs50 and that projector was not the step up I was expecting. So I`m going to look at other projectors up to £2.5k.
    Just food for thought !
  5. theendisnye
    theendisnye
    Oct 11, 2004
    63
    The Optoma H57 doesn't have the level of throw I was after for a 100" screen (from 17') unless there is a different lens available - which I haven't found.
    Steve
  6. ntslik
    ntslik
    Jul 26, 2002
    620
    Cambridgeshire
    +10
    There is an additional long distance lens you can get, I believe it's about £350, i'm trying to find some more spec for you
  7. theendisnye
    theendisnye
    Oct 11, 2004
    63
    Many thanks
    Steve
