Audition recommendations
Discussion in 'Home Cinema Speakers' started by BazH, Jun 17, 2004.
  1. BazH
    BazH
    I am currently looking for speakers in the £1000 bracket (stereo use only). B&W 705s and ATC SCM 12s are on my list at present what else should i be considering a listen with.
    TIA
    Barry
  2. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    10,938
    2
    +3,305
    Triangle Antal- a magic loudspeaker that regularly wins blind listening tests- mainly becaue its no looker. Fabulous and (whilst our own Performance range is still unavailable) where my £1k would go.
  3. Hawklord
    Hawklord
    Feb 15, 2003
    3,441
    Aldershot, Hampshire
    +265
    Linn Ninka's are worth a listen imo have good upgrade options too (bi-wire, bi-amp, tri-amp and fully active with the addition of crossover cards/tune box). Make sure you listen to them with the base upgrades fitted though as they turn them into a completely better animal:)
  4. dts_boy
    dts_boy
    Nov 26, 2001
    2,536
    Manchester suburbs...
    +142
    monitor audio gold reference range is good also. the gr10 are similar in value and size to the b&w 705.
  5. BazH
    BazH
    Good stuff, thanks - any more?
  6. nikyzf
    nikyzf
    What's the main requirement? Bass depth, volume, or sound quality? These will always be a compromise unless you have a large budget!
  7. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,906
    The usual suspects including stuff from Pro-Ac, PMC, Spendor, Totem, Dynaudio and even Ruark are worth putting on the short list for audition. The list could get quite long but £1,000 on a pair of speakers is quite a lot so you want to get it right.
    I'm a fan of the little known Leema Acoustics brand that I have heard a couple of times at the Bristol Show and they are well worth an audition if you can find them
  8. BazH
    BazH
    Main requirement is sound quality, not looking for big spl or earth shaking bass - also the waf comes into play :rolleyes: but if they're good enough i'm sure i could make her see sense ;)
  9. jradley
    jradley
    Jan 16, 2004
    892
    43
    +212
    I would suggest that you take a listen to the PMC GB1's if you can. Not that the Bristol Show is necessarily the best place for judging speakers but in that price range they were one of my favourites there.
    Good luck with whatever you decide.
    John
  10. General Skanky
    General Skanky
    Jul 28, 2000
    4,206
    71
    +44
    What about the ATC SCM 7 + a £500 sub? I know the 7 and think they are brilliant little speakers. And as most people would admit you really do need an active sub to underpin, it's worth a thought. :rolleyes:
  11. BazH
    BazH
    Open to all suggestions, maybe even give me an excuse to buy another SVS :eek:
