Audiophile 2496 AC3 problem
Discussion in 'Desktop & Laptop Computers Forum' started by jmz, Dec 18, 2002.
  1. jmz
    jmz
    Hi all,
    The long journey from zero to home cinema is nearly over!
    I really appreciate all the help I have received by searching these forums. Without them I would have gone bonkers.
    Anyway, this one has me stumped and it's getting late, so I thought I'd ask for help.
    Using PowerDVD 4 XP, I'm trying to get my Audiophile 2496 to send AC3 to my Altec Lansing ADA885. The Hollywood+ card has no problem doing this, thus establishing that the ADA885 is decoding AC3 ok from the s/pdif input.
    The 2496 manual states that you must set the s/pdif output to 'non audio' for AC3 pass through, yet when I do this I get silence.
    I'm not particular what OS or DVD software I use, so maybe some kind soul would give me some pointers, or tell me how they're doing it.
    Best wishes & many thanks,
    James
  2. Branxx
    Branxx
    Nov 1, 2000
    810
    London, UK
    You need to check few things:
    • PowerDVD audio configuration need to be set up to 'Use SPDIF';
    • In windows control panel/audio set up select preferred audio device to Delta SPDIF.
    • Set the PC speaker config to 5.1 or 7.1.
    Audiophile should switch no non-audio automatically when it detects AC3 stream.
  3. jmz
    jmz
    Thanks for the help!
    Only thing I hadn't done was set the speaker config to 5.1. Anyway, PowerDVD still refuses to co-operate. It still outputs nada on the s/pdif, and doesn't switch to non-audio mode (PowerDVD 4 XP, latest patch).
    On the bright side, I have since discovered Zoom player, which works great, but apparently only in 98SE. FYI, I'm using the graph for PowerDVD w Maudio s/pdif, which states not for xp/2k.
    Oh well, win2k would be nice, but at least I can show off my multi-channel system now :)
    Popcorn walla! Juldi juldi!
    James
