Audionewbie amp-question
Discussion in 'AV Receivers & Amplifiers' started by ThAz, Apr 3, 2003.
  1. ThAz
    ThAz
    Im thinking about buying an Nad 302. Im just wondering if you guys think that it will be suitable with my Wharfedale Diamond 8.4 ?
    I know that i should buy a bigger amp, but im kinda broke so this fits my wallet. Anyone who got a Nad amp and Wharfedale Diamond speakers that would take the time to share their experience with this combo.
    //ThAz
  2. gilmore
    gilmore
    I have the Nad 320bee and Nad amps seem to sound more powerful than they actually are. That said the 302 is only runnning around 25wpc am I correct?
    If funds are tight and you are picking it up for a bagain price then would be a good bet but spend a bit more and you will reap better results IMO
  3. ThAz
    ThAz
    Thanks for the reply, yes the 302 gives out 2 x 25W @ 8 ohms.
    This is about all i can afford at the moment :(. Well i´ll probably buy it, it can´t be worse than the amp that drives my speakers now.
    //ThAz
  4. gilmore
    gilmore
    as long as you don't opt for very loud levels you should be fine... I don't know if that model features soft clipping but if it does you might want to consider turning that on if you listen loud.
  5. deckard
    deckard
    Dec 4, 2002
    425
    16
    leicester
    What's the efficiency of your Wharfedales? Speaker power is a strange beast, take Naim power amps for example - 30w per channel from some, but they certainly don't sound underpowered. If your Wharfedales are reasonable efficient ie >89dB/w/m and you don't run things at full tilt then I'd have thought the NAD would be a cracking little amp.
  6. nathan_silly
    nathan_silly
    And on the other end of the scale Sony amps are 100W- but connect 4 Ohm speakers with low efficiency and the itl'll shuts off or get very hot.
  7. ThAz
    ThAz
    My wharfedales are pretty unefficient (86dB/w/m). Well i lost the webauction anyways.
    Im bidding on a NAD AV-713 that gives out 2*60W in stereo mode and im also looking at a
    Rotel RB-970-BX, but then i need a preamplifier, this is getting more and more expensive.
  8. nathan_silly
    nathan_silly
    Why not get a integrated amp?
    Pre-power setup will cost a bit more, not really worth it for a budget system, something like a Rotel RA-971, 70W per channel.
  9. ThAz
    ThAz
    Ok i bought a used Nad C320, went alittle over budget, but hopefully it will be worth it...
