Audiolad 8000CD - Technical Problems - Help Needed
L
LucyvdPelt
i´m already a bit desperate. got the 8000cd about 4 moths ago (i use the 8000s as well) - then one day - no sound ... after checking with my vendor i got the 8000cd replaced with a new one. It was working for some weeks and now i am facing the same troubles again, which makes me think it might be some handling mistake (no - it´s not on mute *gg*) - it must have something to do with the remote control.
did any of you face the same problems, and is there a way i might be spared of taking it back to the vendor again? i´m grateful for any hints.
lucy
