Audiolab Pre/Power with Yamaha DSP? ADVICE PLEASE
Discussion in 'AV Receivers & Amplifiers' started by davidmbell, Jan 14, 2004.
Tags:
  1. davidmbell
    davidmbell
    Jan 14, 2004
    398
    28
    Leeds/Bradford (depends which side of the road I'm
    +24
    Hi there, I currently run an Audiolab 8000A / 8000PX pre/power combination for my hi fi. As I want to keep the good hi-fi 2 channel stereo I added a processor.
    I have a Yamaha DSP-E390 ProLogic processor that I use with this to produce the surround sound output for the rear and centre channels (with its own amp) and then the output to the Audiolabs for the front speakers.
    I want to upgrage the Yamaha to achieve DTS/6.1 etc etc.
    I am not sure how to go about this, do I got for a Yamaha DSP-E800 (which is a little old now but would be a direct replacement) or could I go for A.N. Other Yamaha amp (say with prologic II) that has FRONT PRE OUT.
    Would the Front Pre Out on a 'normal' AV amp give the right signal for my Audiolabs?
    The current DSPE-390 adjusts the level sent to the Audiolabs so when watching a film I set the volume to half on the Audiolabs and leave them there and then the Yamaha controls the overall volume with its own Up/Down volume knob.
    Will a normal AV amp do this too or does the Output from the Front Out Phono not adjust up n down with the volume as it would with a processor?
    Sorry if this sounds complicated.. hope it makes sense.......
    Any advice very much appreciated!
    David
  2. GaryG
    GaryG
    Nov 20, 2002
    744
    Shropshire
    Yes
    Yes
    Can't comment on the Yam stuff but any processor with front L/R pre-outs will do the job.
  3. Reiner
    Reiner
    Jul 16, 2000
    3,315
    61
    Germany
    +13
    Agree, there will be no difference between the dated DSP-E800 (DPL and DD/DTS 5.1 only) and a 'normal' AV amp or AV receiver with front pre-outs, so hooking it up and controlling the volume should not be a problem.
    In case of a normal AV amp/receiver the front amplification will just remain idle.
  4. davidmbell
    davidmbell
    Jan 14, 2004
    398
    28
    +24
    Can anyone recommend a cheap amp with Front Pre Outs?
    Been looking at Yamaha website etc.
    Not fussed about very latest spec, but 6/12months old is ok (DPLII would be nice).
    IT needs to be BLACK too - Not Silver..
    Thanks guys
    David
  5. steveTHX
    steveTHX
    Well you can go for Yamaha RX-v 630 or 640, which has pre out for all channels, and are a pretty good choice for its money. If you go to lower models you will loose a lot of audio quality. Good luck
  6. davidmbell
    davidmbell
    Jan 14, 2004
    398
    28
    +24
    I ended up getting a DSP-E800 from Ebay 2nd hand for £175.
    Thought I'd bagged a bargain from Hyperfi as they had an ex demo one for £169, but they'd sold it by the time I rang them.
    Guess if I get really hooked by stereo in the rear I could sell this DSP-E800 on in a few months and then get a 630/640 (plus they will have come down in price by then.
    Thanks guys!
    David
    ps what's a really good film to test DTS/5.1
    pps my Pioneer DVD player only has phono out/scarts will the right signal be going to the amp? Does it need 5.1 outputs to work?
