Quantcast
Audiolab 8200CD @ 24-bit/192Khz via coax S/PDIF?
mattski
I've got an 8200CD (non OLED) that I am using as a DAC with a MacBook Pro, M2Tech Evo S/PDIF converter (coax) with the dedicated M2Tech power supply. I'm also using Pure Music with iTunes and have set the Evo as the output device at the maximum 24/192 rate.
I'm running into problems with the 8200 locking on to any sample rate above 96Khz via Pure Music. Is anyone using the 8200CD at 24/ 192 as per the spec listed here? Superfi - AUDIOLAB 8200CD CD PLAYER
Thx,
Matt
