Audiolab 8000T info?
mlinhares
I need to find info on this tuner, I searched the web, visited Tag's site, but couldn't find nothing special. Anyone knows where I can find info, tests and photos?
How much is a second hand unit in good shape is worth?
Thank's
Garrett
If you want general info I can dig out some old Hi-Fi mags and look at the back of them if this will help.
I think it was one of the runners up in the What Hi-Fi annual award, and was the best in its price range I seem to remember you need a good aerial with it though..
Audiolab it top equipment.
C
Charlie Whitehouse
I have an 8000T. If you want me to scan the manual for you I would be very happy to do so. ;)
mlinhares
Thank you all. I have the info I needed. The 8000T is, I believe, almost a Tag T20. I'm in a dilema. What I wanted is a Tag T32R, but the price… I have an AV32R and a 100x5 and love Tag gear. Since I can't afford the T32R I was considering a cheaper alternative maybe a used 8000T or a new Marantz ST6000, and later fit a DAB board in mt AV32R. Can anyone give me advice in what should I do?
Thanks.
Nic Rhodes
The T32 is an awesome Tuner, it was what I settled on. The T20 is a little better than the 8000T but not by much. 8000T goes for £600 typically (dealer) which I think is OTT. The T20 nearer £400. Tag did have some factory refurbs but I think they are gone now. Worth asking them though…….
All three tuners are quality bits of kit. If it helps I bought my T32 new (actually ex dem but never turned on!) for £900. Secondhand ones are typically £850, There are some 8000T on the Tag website second hand at £400 and £500 currently if that helps, private sales.
mlinhares
Thanks Beekeeper. I browse the Tag forum, AV Forums, and lots of places every day trying to find a used or preferebly ex-demo T32R (silver to match AV32R and 100x5).
Do you know or does anyone know where can I find one? Pleeease.
Thanks.
yoram611
hi ,
does anybody have owners manual of AUDIOLAB 8000T ??
I would appreciate it very much if someone can scan it for me.
thanks Yoram
Tunerman
I know its from over a year ago, but please could you snd me a copy of your Audiolab 8000T instruction manual - I have one, but could do with a bit of help on interference.
Cheers,
Tunerman
Tunerman
Hi Charlie Whitehouse,
I see from previous correspondence you have a copy of the Audiolab 8000T manual. Please could you send a scan of it to me?
Cheers,
Tunerman
pws
Hi Mate
PM me your address and I'll send you a photocopy of my manual
Paul
Tunerman
I have a copy of the manual from Paul(PWS)from a while ago and will send scans to your email address. Great tuner.
Tunerman (Chris):thumbsup:
