• Welcome to AVForums running Xenforo 2.2. The upgrade from 2.1 was successful and finished in just 90 minutes, well before 8am. The most notable changes in 2.2 are listed in this post.
Audiolab 6000a cutting out
DOTSY502
Hi just wondering if anyone has experienced this also. When I push the amp it cuts off, the display reads PRT and counts down for about 30 seconds before powering back on at a lower volume level. Its connected to a pair of B&w Cm7s. Is that its just not powerful enough? Novice so any advice welcome
DOTSY502
I did indeed. The solution was to get rid of it 😁. Prt is protect mode meaning its not able to be pushed to that level as it just isn't powerful enough.
Rob Hogan
I’ve had an hour of two playing around and sorted it. Not sure why it’s fixed it, but I disconnected the speaker cables, gave the exposed cables another twist, inserted them back in and bobs your uncle. (ps. they were 100% connected correctly + and -) ...but this seems to have sorted it and I can now push it very loud. Running it through Dali Oberon.
DOTSY502
Fair play Rob I might have been a bit hasty! I was using a pair of cm7s and they just kept cutting when I pushed and to be honest I do push them. Glad you got it sorted lad
Disable the "Audio Clock Trim" in Bluesound Node 2i settings if using an external dac. Settings>Player>Audio>Audio Clock Trim. It affects external audio converters especially ESS Sabre dacs leading to dropouts jitter etc. Once disabled your music should play fine without dropouts or jitter.
Podcast: Q Acoustics Q3030i, Humax Aura, Roku Streambar & WandaVision Reviews and more...
