AudioEngine Speakers?
Hi guys
Does anyone on here use AudioEngine speakers?
I'v been looking at getting a white set of A2's for the iMac and some black A5's for the TV / Front room.
Has anyone got any experience of them, sound wise?
recommendations or not?
cheers
Dave
cuttsy
I have the A5's in my dining room as part of my airtunes set up and LOVE them.
I also bought the A2's for work to use at presentations and they are very good as well. I have some sound sticks as well but the audioengine's blow them away.
I would highly recommend them.
The only thing to be aware of it the so called airport socket on the back of the A5's needs a special adapter, the US adapter plug for airport did not fit so I plugged the airport direct into a four way strip, not a big deal.
The only other thing to consider they don't have a remote so turning the volume up and down has to be done through itunes (itouch/iphone remote).
Peridot
The mixture of shapes / sizes / colours in my AV setup shows that brand loyalty means nothing to me, but I have got two pairs of A5s and a pair of A2s :)
I have the A5s linked to Squeezebox streamers in two rooms and the A2s connected to my Powerbook. I don't believe that it's possible to better the A5s with separates at a comparable price level - one of mine replaced a good Rotel / Mission setup and improved on it significantly.
The A2s are fantastic for their size although I'm not 100% happy with their bass handling. I haven't had them long and expect that playing around with their positioning may improve matters. They're still head and shoulders above any other 'computer' speaker - just suffering from my 'A5' expectations :)
For the use you're describing, I doubt you'll be disappointed.
