Audio
Discussion in 'Desktop & Laptop Computers Forum' started by Ajax, May 25, 2004.
  1. Ajax
    Ajax
    Feb 4, 2004
    170
    Hello,
    Does playing DVD's via a HCPC cause many lipsync problems? I would need to run a 20m digital cable from my PC to the AMP. Am I right in assuming that this would be unadvisable?
    Cheers,
    Ajax.
  2. drummerjohn
    drummerjohn
    Sep 2, 2001
    2,497
    South Derbyshire
    +205
    20 metres -
    Optical - no way
    Coaxial - maybe. 5 Metres was fine for me.
  3. Chipster
    Chipster
    Nov 12, 2003
    203
    UK
    10 mtr coax works fine for me, I guess you will just have to try it. Good cables can be a bit expensive so make sure you can get a refund if it dosent work with 20mtrs.
  4. rOAdeh
    rOAdeh
    Jan 24, 2003
    648
    Winchester
    +5
    can i just ask why you reject optical technology as being capable of handling such a 'long distance'. id have thought from what i read and learned doing my uni course that optical runs would be generally superior over long runs compared to coaxial assuming all other factors were equal
  5. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    Yes but that is with proper optical cables, not the rubbish sold for AV. It also depends on the transmitting and receiving devices.
