audio video sync issues
christhedon
there seem to be problems with playing divx files. The audio is quite a bit out of sync with the video.
Does anyone else have this issue and know how to fix?
I've got kazaa lite codec and a fast laptop dual core 2.4ghz..
Cheers,
Chris
Badger0-0
Is it with all DiVx or just a particular film?
If the latter, it's most likely down to the encoding.
spyder viewer
Are these downloaded DIVX files or files you have encoded from DVDs or TV recordings?
N
nburg01
Does the audio synch get worse as the film progresses or does it stay about the same amount out of synch throughout?
anoraknophobe
christhedon - did you ever get this sorted? I'm having the same problem. Mainly divx files I've created using the Divx Converter. Can you use ffdshow to convert files to Divx?
