Audio video capture device
Discussion in 'Projectors, Screens & Video Processors' started by steve in derby, Jul 8, 2005.
  1. steve in derby
    steve in derby
    I am seeking advice on the best device for the job below.....
    I have a lot of sporting videos on vhs cassettes and i want to put some clips onto a laptop which runs windows xp and then project these through a sanyo high power projector across a sports hall.
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,132
    Rainham Essex
    +2,393
    To get the best quality from the VHS to laptop you will need either a DV camcorder with AV-in enabled (most sold in UK have AV-in disabled, so check specs closely) or the very good Canopus ADVC converter. There are several Canopus models, but if all you want is to display video then the basic model should be good enough.
    The only thing you need on the laptop is plenty of disc space as AVI video & audio files (the file format that will be on the laptop) take up approx 14Gb per hour. You could always compress the files to save space though.
    The only other thing you need is a firewire port on the laptop to connect the camcorder or converter to it.
    You will find loads more help and advice on this in the 'Camorder & video editing' area of these forums.
    Mark.
  3. Mark_a
    Mark_a
    May 27, 2005
    2,891
    +496
    You can also use an A/V Pyro link from ADS.
    http://www.adstech.com/products/API-555/intro/api555_intro.asp?pid=API-555
    Like the Canopus it's got hardware sound syncing and so even long captures remain in sync (something you can say of cheap an' cheerful USB capture boxes). It's also got component in and out so will capture in very high quality.
    The trouble is that both the Canopus and the ADS Pyro Link cost more than a cheap stand alone DVD recorder, which I would suggest would be one helluva lot easier to use, and will produce results as good as you're likely to get from VHS tapes in the first place.
    Regards
    Mark
