I'm trying to replace the old AVR in my home theater setup with the Platin Milan 5.1 + WiSA SoundSend wireless system but I can't get any audio working.
What I have:
I assumed that the HDfury AVR key would work to send audio to the SoundSend but it doesn't seem to be registering any input and I have video but no sound. Is the issue that the SoundSend is designed to be connected to TVs via ARC/eARC connection and it doesn't recognise non-ARC input?
Can anyone recommend a simple fix? I suspect there must be a way to get audio to the SoundSend via HDMI or optical using some adapter. From the research I've done so far I gather there may be issues with getting 5.1 audio from apps like Netflix if I go for optical. I'm a bit out of my depth understanding the differences between various audio formats.
Thanks in advance for any help!
What I have:
- Nvidia Shield TV Pro
- Epson EH-TW9400 projector (only has HDMI inputs and no audio out)
- WiSA SoundSend (has HMDI and Optical inputs) to transmit to platin 5.1 speakers wirelessly.
- HDfury AVR key (was using this to split Shield output into video to projector and audio to old AVR)
- [email protected]/[email protected] 48Gbps HDMI cables x3
