audio testing problem
Discussion in 'Home Cinema Speakers' started by phoebe, Nov 16, 2004.
  1. phoebe
    phoebe
    Hi there,
    i have a few question about speaker,and need ur help here.
    Sometimes when i listen to the audio,i can hear clearly that the sound lacks of warmth/focusthe,but hard to quantify, do there any document to judge it?
    And do the speakers get tuned in some way even after passing the tests?
    Thank you.
  2. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    Hello Phoebe,
    I am not sure that I understand your question but many speakers sound very different to each other. Some speakers are very cold and dry whilst others seem to be much warmer.
  3. phoebe
    phoebe
    Thank you Ian.
    Do there have any written document/FAQ on how you test and evaluate the audio sound?
  4. phoebe
    phoebe
    I also want to know do a pair of speaker sound bad even though it has passed the audio test?
    Because sometimes when I listen to the music at home, I feel the sound not very well, but the speaker I bought from the vendor should be passed all the test, is this problem just my subjective feeling or is it the speaker’s problem?
    Phoebe
  5. phoebe
    phoebe
    Do anybody there can give me a hand?
  6. JurgenNL
    JurgenNL
    Jun 12, 2002
    282
    +20
    Hello Phoebe,
    May I suggest that you try to get some information about valuating the sound?
    You could start with e.g. the advice that What HiFi gives (in paper, but more extended on
    http://www.whathifi.com/soundadvice.asp
    Jürgen
  7. phoebe
    phoebe
    Hi Jürgen,
    Thank you for ur kind suggestion :)
  8. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    It can be a mixture of factors that can affect the sound of the music including the make of amp, the quality of the source eg cd, record etc. The make of the source player, the interconnects and the speaker cables.
    In the end though its your ears that appreciates the sound or hates it.
  9. Paulbmw
    Paulbmw
    dont quite understand question but you generally find that a speaker with a lower Hz output sounds warmer. i.e a 40Hz speaker is warmer than a 60Hz speaker
