audio sync
meva
I've downloaded the FOTR WM9 AC3 OAR sample to check out some WM9 hidef. the video runs nice and smooth but the sound is way out of sync ( 5 secs ahead ). Is this due to an underspec pc ( Athlon 2100 and Radeon 9200 ) or is this a codec/filter problem? Using WM9 (obviously) with the AC3 filter 0.70b.
Thanks.
P
pdundas
If you're talking about the clip which has been floating around the last month or so then I think it is 1920x1080 so would require something like a P4 3.0+ to playback without dropping frames and losing sync.
meva
Thanks, thought so.
I just watched a HD t.s. clip of The Two Towers on my Z2.Makes dvd look mighty soft. I can't wait now for blu-ray/hd-dvd now.
Podcast: New Denon AV Products, HDMI 2.1, 8K, DTS:X Pro Sound Q&A with Denon Product Specialists
