Audio Sync trouble
Discussion in 'AV Receivers & Amplifiers' started by richjthorpe, May 3, 2005.
  1. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    Hi all,
    I've got a Denon 1601 AV Receiver linked to Canton CD-1 and sources of Digifusion Freeview box and Marantz DV4100 DVD player.
    The problem I have is that the lipsync is out and you can hear the sound before the video. It's only slightly out and on some programs you can't even tell, but it is there.
    I've tried setting the distance from the centre channel to the lowest and then to the highest from the listening position but nothing affects it. I haven't tried setting the dB levels on it though.
    What am I doing wrong ?
    Thanks,
    Richie.
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,335
    Rainham Essex
    +2,433
    Is it only when viewing Freeview channels that you notice the lip sync error? Or do you notice it with a DVD as well?
    If it is only when watching Freeview, and only on certain channels then I'm afraid there is very little that can be done. The cause of these problems is that some channels get out of sync at transmition. I find that Sky News is the worst affected channel, and most of the other news channels are almost as bad. This is due to the fact that the camera is mainly pointing directly at somebody whos is talking, and you are consentrating on them speaking so any delay is more obvious.
    Some AV receivers have a master audio delay feature, but not normally the budget models. Without the master delay it is impossible to accurately set up the receiver to correct the lip sync error.
    If the Freeview box has a digital audio output then you can get a delay unit from Felston that will be able to adjust any delay as required to get the video and audio back in sync.
    HTH,
    Mark.
  3. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    Thanks Mark, I'll have to take a look at a DVD tonight. I thought it did happen but haven't watched one for a while !
    Cheers,
    Richie.
