Audio Splitter
Discussion in 'Cables & Switches' started by OhPinchy, May 19, 2005.
  1. OhPinchy
    OhPinchy
    May 19, 2005
    171
    +4
    Not sure if this is the right place for this post so feel free to move...
    I am setting up my Windows Media Center PC so that I have VGA cable running from the Media Center PC in Dining Room to both the TV in the Living Room and Main Bedroom. I will be using a VGA splitter to do this (have decided against Extenders for the time being). Will most LCD TVs accept a VGA input?
    I will also need to run audio cables from the PC to the two other TVs - I'm not sure how to split this signal. My main question (which isn't Media Center specific which is why I thought I should post it here) is: how can I split the audio output from my PC's sound card so that it runs to the two other TVs?
    Thanks.
  2. inzaman
    inzaman
    Dec 16, 2002
    7,887
    Derby
    +939
    I have moved this to cabling for the second question.
    For the first question you may want to post a separate thread in LCD TVs :)
  3. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,284
    The Borders
    +2,573
    OhPinchy
    If I'm understanding your requirements correctly then a Kramer VP-2xl VGA+Stereo audio 1:2 Distribution amplifier will do the trick.
    See http://www.kramerelectronics.com/indexes/pic.asp?p=VP-2xl
    Best regards
    Joe
    PS I'm sure it wont be a problem to specify/supply LCD 'TV's that have a VGA input.
