Audio Spec.
Discussion in 'Blu-ray & DVD Players & Recorders' started by eddyng, Jul 18, 2002.
  1. eddyng
    eddyng
    I'm comparing between the spec. of two DVD player and is confuse with the audio spec.
    One featuring 192KHz/24-bit audio D/A converter
    the other 96KHz/24-bit audio D/D converter
    My understanding is that the difference is on the sampling freqeuncy.
    Does it means that higher sampling frequency, better audio performance??
