audio problems
Discussion in 'Blu-ray & DVD Players & Recorders' started by jammyb2004, Jan 15, 2005.
  1. jammyb2004
    jammyb2004
    Apr 12, 2004
    1,113
    63
    +113
    hey!
    first post in this section so forgive the reposting :D
    i have a JVC DR-M10SLB DVD Recorder, i've been having problems with certain DVDs but have managed to fix them, but i've got this one DVD. i burn it on the PC, i've re-ripped it and even burned it menuless but i get the same problem!
    the problem is the video plays fine, but the audio is like a second on, a second off, a second on, a second off.
    e.g. "hello, my name is jammy, i like the AV forums" would sound like this "he , my na is ja y, i li the A foru "
    if i fast forward the video and then rewind back to the beginning, it fixes it. but then it mite come back again later.
    if i play the dvd's (i've got a couple now) they ALL play perfectly fine in other players. its just the JVC!
    wat do i do? any ideas? i need to fix it! otherwise i'm ebaying this thing!
    thanks,
    jammy
