Audio problem
Discussion in 'Home Cinema Speakers' started by eddie64, Jul 22, 2004.
  1. eddie64
    eddie64
    Hello everyone I have a Sony DAV-S550 for a while with no problem it is fine for what I need but I wanted to hook-up my record turntable to the system through the m/f phono leads,it works but even with the Sony on maximum
    power there is very low output audio wise, can anyone give me any clues as I am baffled as the turntable has no volume control on it as it was part of my old Hi-Fi system.
  2. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,229
    2
    +3,716
    You need a phono stage. The signal from a turntable is generally on one tenth the strength of that from a CD player or similar. In the case of the sony, you would need an external unit which normally takes the form of a little black box from about £20 upwards. Look at the usual suspects, Richer, maplins etc.
  3. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
