audio problem with TMPGEnc
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by electrolyte, Sep 26, 2003.
  1. electrolyte
    electrolyte
    Feb 3, 2002
    4,030
    Sheffield
    +1,045
    I've had problems when using TMPGEnc to encode MPEG-2 for SVCDs. I have created about 6 different MPEG-2s in the last 3 months and each time the audio is out of sync with the video (approx 0.5 secs behind). Has anyone else had this problem and got a solution?
    I edit my videos using Pinnacle Studio 7 SE, create an AVI using Pinnacle and convert the AVI to MPEG-2 using TMPGEnc. I use the highest quality PQ settings in TMPGEnc and so a 20 min film takes approx 8 hours to encode. I then burn the SVCD using Nero. I do all of this on my Mother-in-law's PC as mine is not up to the job (she lives 3 hours away from me so I don't get many chances to experiment with this). She has an Athlon 2.4 Ghz, 40 GB HDD, 512MB memory. There is no problem with the audio sync when I play back the AVI on the PC. The audio sync is detectable when I play the MPEG-2 on the PC so I am sure that Nero is not at fault - it must be TMPGEnc. Is there something I am doing wrong??
    Any ideas??:confused:
  2. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
    Are you using DV camera or analogue ?
    Dropped frames in capture may not show up as readily in your .avi file but may become more apparent when encoded & lead to sync problems.
    Is it consisitantly the same length out of sync start to finish ?
    Have you tried playing back on several different computers to see if that makes a difference ?
    There is a program PVAstrumento that can apparently cure sync problems in MPEG files. ( Never had to use it myself)
  3. electrolyte
    electrolyte
    Feb 3, 2002
    4,030
    Sheffield
    +1,045
    Thanks for your reply vonhosen
    I'm using a Sony Digital8 DV cam
    The sync is wrong by the same length at the start as it is at the end. Haven't tried it on several computers as Mother-in-law is only person I know who has a fast enough PC, firewire port and video editing software. The sound is out of sync when I play the SVCD on her PC and on my standalone Tosh 220 DVD via my TV.
    Thanks, have downloaded this and will try it out when I next go up to see her in November. Really must save up for my own PC!!
    Does anyone else know if I there is a setting in TMPGEnc that will correct for this lip syncing problem?
  4. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
    I can't honestly see it's TMPGEnc that will be the problem, or a setting in TMPGEnc that can help cure your lip sync.
    Here is a link to Rui's guide . This will give you a good idea of what the MPEG-2 settings in TMPGEnc are for. Just remember what the resolution and max bitrates etc are for SVCD as these examples are for DVD compliant files.
