Neil Bruce
I have just bought a BDPS350 bluray player and I'm having problem with connecting it to my home cinema set up. I'd really appreciate any help with this.
I have a Samsung HTX250 all-in-one player which accepts input via digital optical. However when I attach the BDPS350 I get no sound at all. If I take the optical cable out of the bluray and plug into another device there is no problem with the sound through the Samsung box so I know there isnt a problem with the cable or the connection. Sound from the bluray through the TV via the HDMI is fine as well.
I currently have the sound configuration on the bluray set up as follows
Audio Output Priority: Coaxil/Optical
Audio (HDMI): Auto
BD Audio Setting: Direct
Audio ATT: Off
Dolby Digital: Dolby Digital
DTS: DTS
48kHz/96kHz PCM: 48kHz/16bit
Audio DRC: Auto
Downmix: Normal
I have tried a number of setting such as changing the Dolby Digital and /DTS outputs to Downmix PCM but I still dont get any sound.
Does anyone know if the Sony is not compatible with the Samsung system? Are there any known issues with the player.
Thanks for your help
Audio (HDMI): Auto
Audio ATT: Off
DTS: DTS
Audio DRC: Auto
Downmix: Normal
