Audio Proble 2900
Discussion in 'Blu-ray & DVD Players & Recorders' started by Mike Delvaux, Oct 12, 2004.
  1. Mike Delvaux
    Mike Delvaux
    Hi :lease:
    Can any one help me I've an audio problem on my Denon 2900 it's ok through
    the amp, but as soon as I want audio through TV on its own I get a problem.
    No speech just a few affects and music from the film. It's ok with the trailers etc but as soon as the film starts in 5.1, no speech at all.
    I have component and scart fitted. Can any body help or has any body had
    similar problems. :lease:
  2. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
    Sounds like you are just getting the front left & right channels of the 5.1 mix (speech will be in centre channel). You need to get the 5.1 downmixed or listen to the 2.0 output.
  3. Mike Delvaux
    Mike Delvaux
    Some DVDs dont give u the option to listen to 2.0 output,I also thourght
    the player was supposed to down mix the audio when using RGB. But I
    probaly am doing something just dont no what ?.
