Audio pro or tannoy with denon3805
Discussion in 'Home Cinema Speakers' started by rmask, Mar 25, 2005.
  1. rmask
    rmask
    Mar 25, 2005
    115
    +4
    which system would you recommend and why, with denon 3805
    listening room is 24 sq. meters
    music/cinema ~ 70/30%
    music: classical (string orchestra and piano mostly), jazz, acidjazz
    1. Tannoy:
    Sensys DC2 fronts, sensys s2 backs, Sensys DCC center (sub will come later)
    http://www.tannoy.com/SensysDC2
    2. Audio pro:
    Blue diamond v2 fronts, black diamond v2 backs, black vector v2 center
    Blue diamonds come with integrated active 175W 10" subs (similar to much more expensive polk LSi15)
    http://www.audiopro.com/products/image_12.asp
    Personally they both sound pretty good to me (althou i havent tested any of those at home), but audiopro's sytem looks a lot better, integrated subs save room space , the only concern is that all of audiopro's are rated at 4ohms ... i'm not sure how denon will handle it(althou each speaker has only one midrange and a tweater, and bluediamonds subs are powered by built-in amplifires)
