Audio pins on SCART - Do they matter when using optical/coaxial
Discussion in 'Cables & Switches' started by sideysid, Jan 2, 2005.
  1. sideysid
    sideysid
    Jan 2, 2005
    471
    +31
    Fairly new to this game, so bear with me if the questions been answered previously as I cant seem to find an answer.
    The question is regarding a freeview box with 2 SCART connections (1 RGB), and also with an optical out. I will be using a SCART cable that has both audio and video to connect to my LCD TV, and using a optical lead to my av amp for the audio.
    Do I need a specific RGB only SCART cable, or is a normal SCART the same thing?
    Also will the audio pins on my existing SCART cable interfere with the sound - if I just want the digital output via the optical lead?
    Many Thanks
    :confused:
  2. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    No problems at all using a fully wired scart to the TV plus a digital connection to the AV amp.
  3. sideysid
    sideysid
    Jan 2, 2005
    471
    +31
    Thankyou very much for the reply, looks like I'll be using the RGB SCART on the Freeview box over the S-Video then if a fully wired SCART doesn't interfere with the sound... :D
